I have always used DVD Shrink, Anydvd, Nero Sony version 6.3.1.19, an Older Sony burner and a Dell Dimension 4100 with WinXP and 512 of ram and Maxell DVDs burnt at the lowest speed.
I recently purchased a Dell Inspiron with 3 gig of ram and an Optiarc burner. I lost my Nero version 6.3.1.19 so I am now using Nero 5.5.10.56. So I am using an Inspiron 530, an Optiarc 7200S, Nero 5.5.10.56, burning at the lowest speed, and am playing it back on a Panasonic DVD-F87.
Since I have switched to the new computer, I have had trouble watching the DVDs. In the middle of the DVDs, they keeping pausing and skipping so bad, the DVD is unwatchable.
I think it might be the DVD player so I purchased the best cleaner I think I could find, a Maxell, I used it twice to see if that would help. It didn't. I then thought it might be the blank DVDs. I switched from Maxell to Verbatim. Still won't work. Could use some help.
Thanks!
Instead of Nero, use Imgburn to burn your DVDs; it is free and it is available at this website in the "Tools" section. You might also want to try DVDFab HD Decrypter which is also available here. Even though you use AnyDVD, it is a great (free) application to have for ripping newer releases.
I downloaded and installed the latest version of Imgburn but I am not quite sure how to use it with Dvdshrink. I mean I think you still use it with DVDshrink and Anydvd. Sorry, I'm just a fat old guy that had to retire early cause of cancer so sometimes I am a little slow at new stuff. Spent two months in a coma and total of three months in the hospital this time last year. I was even slow waking up.LOL!! I was slower getting out of the hospital!LOL!
I presume you have been using DVD Shrink with ANYDVD to rip the disc to the hard drive. Following that process, just use Imgburn in place of Nero to burn the DVD.
To open the program, click on the desktop icon.
At the top of the Imgburn interface are the options "file", "view","mode", "output", "tools", and "help".
Click on "help" and select the second option, "view Imgburn guides". The guides will provide the information needed to use the program.
Practice using + or - RW blanks until you feel comfortable with the program.
There is a learning curve, but it isn't steep; if I can learn to use it, anyone can !
The results are worth the effort, and in the learning process you will discover a number of other very useful features included in this great application. In the long run, you'll save money and time by not having those failed burns.
Have fun, and good luck ! -
arbutler;
Something else I should have mentioned. Perhaps your new burner is not compatible with Maxell media.
Along with burning with Imgburn, try Verbatim or Taiyo Yuden blanks; those two brands seem to give the best results overall. If you are near a Best Buy or Office Max, they stock Verbatim. You'll probably have to mail order the Taiyo Yudens; www.rima.com seems to be the preferred place to buy. If you decide to get Verbatim, look for "made in Taiwan" or "made in Singapore" on the label as many people (including myself) have realized better consistency of quality with them than the Verbatims which are made in India.
watch movies on a panasonic camera ?
By kissber in forum Newbie / General discussionsReplies: 4Last Post: 13th Feb 2012, 22:46 -
converting movies to watch on dvd players
By dustincapp in forum MacReplies: 14Last Post: 1st Sep 2011, 23:30 -
Watch MPEG2 SD Card Movies on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 2Last Post: 10th Apr 2011, 16:08 -
watch dvd movies on computer
By jfmalone in forum Software PlayingReplies: 10Last Post: 13th Feb 2008, 17:30 -
making panasonic DVD-F87 Region free
By peepcharron in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jul 2007, 20:24
