Hi, im attempting to capture some gaming footage from playstation 3, but its harder than i thought.
The plan was to connect the playstation 3 HD tape recorder, and then work with it from there.
But the guy who helped me, said that the HDMI signal is copyprotected, and probably why we just get a balck screen when trying to record it.
Does anyone have a trick?
Yes, HDMI is copy protected to prevent you from using it as a copy source.
You have to use some kind of analog source like composite/component/S-video. And note that some games output PAL60 signals in Europe and such signals may be impossible to capture with some devices. -
Oh damn..
..but you say theres a change using the component(rgb)?
(the problem is that the taperecorder cannot take component, maybe it can take composite(it should))
I didnt think i could use the composite (the yellow phono), can it pull HD?
Any other suggestions?..
For future recordings..what hardware would be remendable..(thinking of the pal60 sissue) -
There alway the Hauppauge HD PVR which has Component video input
Capture card for PS3
By restarts in forum Capturing and VCRReplies: 14Last Post: 6th Nov 2011, 17:52 -
Problems running software to capture PS3 game play?
By Agent 0008 in forum Capturing and VCRReplies: 9Last Post: 31st Mar 2011, 16:50 -
Ati All In Wonder HD and PS3 screenshots and capture HD video.. help needed
By C.P in forum Capturing and VCRReplies: 6Last Post: 30th Mar 2010, 17:46 -
Simple question about video capture from ps3
By adamsbomb in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2010, 00:48 -
how 2 play ps3 hd on tv and capture 2 my pc not hd
By wgpblade in forum Video Streaming DownloadingReplies: 0Last Post: 21st Feb 2009, 11:22
