I just attached my new Samsung 1080P 32" tv (LN32A550) to my HP DV2700 14" laptop. The laptop only has VGA out, no DVI or HDMI.
The TV has PC IN (VGA), as well as HDMI and DVI.
I use Windows Vista.
It worked as soon as I plugged in my VGA to VGA cable, however, unless I reduce my laptop resolution 800x600, the HDTV will only show a partial screen. If I set the laptop at full resolution, then the corresponding screen size on the TV will to large so the borders and scrolling tabs are off the TV screen?
Any hints.
I assume VGA to VGA is my only choice, but I hate to waste those DVI and HDMI inputs on the TV.[b]
not sure I understand, but I selected PC input on the TV, and that is VGA?
Still no good. I have to set the laptop resolution at minimum, 800x600, to get the full screen on the TV? If I set the laptop resolution higher, the right side of tv screen is not complete and does not show my full laptop desktop.
caN YOU independently set the tv resolution without upsetting the laptop resolution? They seem to work in tandem.
Try 1920x1080 at 60 Hz. I run my older Samsung LNT-4665 that way (via HMDI but you should be able to use VGA too).
Look in your HDTV manual. It will tell you what resolutions and refresh rates are supported.
Laptop LCD screen to TV
By cynikalhedonist in forum DVB / IPTVReplies: 4Last Post: 28th Apr 2011, 09:07 -
Laptop dvi / hdmi connection to HDTV screen flicker black
By vettesea in forum DVB / IPTVReplies: 0Last Post: 24th Apr 2011, 15:35 -
Could the in-movie icon lead to burn issues on 60hz lcd hdtv? bluray+hddvd
By yoda313 in forum DVB / IPTVReplies: 5Last Post: 26th Feb 2011, 11:15 -
laptop screen size too big
By angryassdrummer in forum ComputerReplies: 7Last Post: 14th Feb 2011, 23:20 -
Issues while connecting IBM T42P laptop with Sony 46" XBR3 lcd tv
By nikulb in forum Newbie / General discussionsReplies: 4Last Post: 21st Jul 2007, 18:52
