so aynway just joined this to see if anyone can shed some light on the situation....
i wanna get a blu ray player but......was wondering will it play downloaded movies and if i need to have a HD TV in order to view downloaded movies that are in HD DVD format????
thanks
You do not need an HDTV to view BluRay movies on a BluRay player, but not having an HDTV defeats the purpose of having a BluRay player.
It's impossible to guarantee you that downloaded movies will play on a BluRay player. It depends on what format the movies are in and whether your BluRay player supports that format or not. Divx/Xvid support is growing in BluRay players, but other formats (H.264, WMV) won't be supported at all without conversion. BluRay players may not support the older VCD and SVCD formats, but you probably won't be downloading those. -
ok so......is there much of a difference in the quality of picture if i were to watch bluray on just a normal widescreen tv???
As opposed to a regular DVD on just a normal widescreen tv. Probably no difference since the bluray is being downconverted for your regular (non-hd) tv.Originally Posted by deadgirl"Art is making something out of nothing and selling it." - Frank Zappa
Burnt XVID looks awful on DVD
By skribby in forum Authoring (DVD)Replies: 5Last Post: 16th Aug 2009, 12:56 -
Burnt Blu-ray not playing on PS3
By cyberpimp16 in forum Blu-ray RippingReplies: 1Last Post: 14th May 2009, 12:53 -
Burnt DVD with vob problem (not playing on computer)
By lamaddvd in forum Newbie / General discussionsReplies: 7Last Post: 17th Feb 2009, 15:28 -
burnt dvd's freeze 3/4 through the movie
By sc0rpthir13en in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2008, 20:40 -
burnt dvd does not play
By sumeshkri in forum Authoring (DVD)Replies: 12Last Post: 22nd Nov 2007, 02:33
