I am trying to author a DVD using muxman.
The srt is in properly synchronized, the .sup file is also well synchronized (tested with Subtitle Creator, timing checked). After muxman finishes it jobs, the sup is a little bit late. DVDSubEdit shows that the sub now is +0.260 second (constant to all sub lines).
I'm just learning so I don't know if it's common or weird.
Please advise me.
Thank you
Actually I don't know. But 0.26 seconds is hard to detect anyway. Maybe that's why nobody complained about it yet.
I would try to check the timing with the same program before and after authoring.(tested with Subtitle Creator, timing checked). After muxman finishes it jobs, the sup is a little bit late. DVDSubEdit shows that the sub now is +0.260 secondGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
A quarter of a second is noticeable, I think. Not as noticeable as audio off by a quarter of a second, but still noticeable. I'd find it annoying, if they had been properly synched to begin with. But I've never had the problem. As far as I know, Muxman has never been responsible for changing the sub times for me.
I think I agree. Open the SUP before authoring in DVDSubEdit and check if the times are the same or 0.26 seconds off from the subs after authoring.I would try to check the timing with the same program before and after authoring.
If, when playing the new DVD you find them delayed, qknet, although you might not be happy with the result, you know it's also easily fixed using DVDSubEdit.
Problem with Muxman and PAL DVD's...
By tomfoster in forum Authoring (DVD)Replies: 5Last Post: 9th Aug 2009, 04:51 -
Muxman generates a dvd with only single chapter??!!
By StarX in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2009, 04:24 -
Problem when using muxman to author DVD
By ihmcjacky in forum Authoring (DVD)Replies: 17Last Post: 27th Sep 2008, 03:03 -
Add subtitles to a series DVD, not just a movie (problems with Muxman)
By gimeis in forum Newbie / General discussionsReplies: 24Last Post: 9th Sep 2008, 01:39 -
Please HELP: How can I add a box score/time clock to a sports video?
By MaTTuP in forum EditingReplies: 5Last Post: 23rd Aug 2008, 12:40
