hi ...
I have MKV Movie and i want convert to MP4 . and i have srt sub and i want add this sub to the movie
using Megui . haw i can do that ?
Use xvid4psp instead, load mkv, load subtitle(srt), select mp4 under the profile, set encoding settings, encode. Done.
If you want help with megui then search http://forum.doom9.org -
If you mean hardcoding, just use VSFilter
Just add TextSub("PATH\file.srt") to the .avs script
http://avisynth.org.ru/docs/english/externalfilters/vsfilter.htm
Another option - depending on what your .mkv contains, if you don't want to re-encode the .MKV (lose quality), you can just switch containers to .mp4 with YAMB. This takes a couple minutes as opposed to hours re-encoding, but softsubs don't work as well in .mp4 compared to .mkv (kmplayer is the only software player that plays subs inside .mp4 containers reliably - vlc, smplayer, mpc don't work as well in this case)
Edit Subtitle Megui
By bebado22 in forum Video ConversionReplies: 2Last Post: 28th Sep 2010, 22:13 -
How to change srt Subtitle style and font size in MEGUI ?
By DARIFBS in forum SubtitleReplies: 4Last Post: 12th May 2010, 15:19 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 18:03 -
MeGUI subtitle support (or alternative app recommendation)
By trooper11 in forum Video ConversionReplies: 7Last Post: 18th Apr 2008, 20:20 -
Subtitle Color Yellow, Megui?
By bebado22 in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 17:14
