I downloaded a film (I own the film legally but the disc is scratched). The film is 2 hours and 30 mins. Surprisingly the file is just over 700mb. It is a Divx/XVid. I played it on my PS3 and the quality is fantastic. I have tried many times to convert another DVD of mine which is bout 2 hours to divx but im gettin 3gb+. I cannot fathom a way to have good quality and low fize size. Anyone have anyhing to help me with doing this?
the one may be farmore compressible than the other.
if you want a fair estimation,
upload a sample of the downloaded file you find to be good quality,
and a sample of the dvd you are trying"I'll give you five dollars if you let me throw a rock at you" -
What settings and software are you using?
Try use a lower resolution/frame size and low audio bitrate(128kbits mp3). Use 2-pass encoding and convert with AutoGK or Fairuse Wizard. -
file size = bitrate * running time
If you want a smaller file use a lower bitrate. -
Reducing the resolution also allows you to get away with lower bit rates. The great quality download you have may have a much lower resolution than the one you made yourself. It would also be good to know what exactly you are using to convert to Divx as maybe you are using a tool that isn't very user configurable. For example the Divx Converter program could not be simpler to use but you basically can't configure anything in it, so it's completely inappropriate for what you want to do.
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 01:53 -
how to make a dvd with lot of small video files?
By sumeshkri in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2010, 10:13 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
How to make a small file with videodub?
By benvid in forum Video ConversionReplies: 5Last Post: 22nd Feb 2010, 07:42 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
