Has anyone had this problem?
TMPGEnc starts by creating a temporal wave file.
Then TooLame will encode the wav to mpa.
At this point, sometimes TMPGEnc will just close and leave a 0 byte MPG file in the output folder.
If I extract the WAV file separately first, then tell TMPGEnc to use separate files, it works OK.
It also seems to do this when running Batch Encode (probably the same root cause).
Extracting to WAV first is a bit of a pain.
P.S. I'm on Windows XP Pro - latest version of TMPGEnc
Results 1 to 1 of 1
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 22:56 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
