  1. Member chazuke's Avatar
    Oct 2008
    Germany
    Situation:
    Have got here a DVD (music concert, 7 tracks), obtained as a download, with unusual/inconvenient/false authoring.
    Problem 1: The DVD is authored in a way that access to each of the 7 tracks is only possible through the root menu. A continuous playback stream does therefore not work.
    Problem 2: Although filmed & encoded in anamorphic 16:9, the DVD's aspect ratio is falsely set to 4:3.
    Details:
    The DVD has the usual folders VIDEO_TS ; AUDIO_TS ; EXTRAS_TS
    Here is the list of contents of the VIDEO_TS folder: (Image: http://i240.photobucket.com/albums/ff292/chazuke/UO0002.jpg)
    VIDEO_TS.BUP 16KB
    VIDEO_TS.IFO 16KB
    VIDEO_TS.VOB 40KB
    VTS_01_0.BUP 16KB
    VTS_01_0.IFO 16KB
    VTS_01_1.VOB 231.404KB
    VTS_02_0.BUP 22KB
    VTS_02_0.IFO 22KB
    VTS_02_1.VOB 476.818KB
    VTS_03_0.BUP 16KB
    VTS_03_0.IFO 16KB
    VTS_03_1.VOB 192.966KB
    VTS_04_0.BUP 16KB
    VTS_04_0.IFO 16KB
    VTS_04_1.VOB 159.817KB
    VTS_05_0.BUP 16KB
    VTS_05_0.IFO 16KB
    VTS_05_1.VOB 200.960KB
    VTS_06_0.BUP 16KB
    VTS_06_0.IFO 16KB
    VTS_06_1.VOB 268.456KB
    VTS_07_0.BUP 16KB
    VTS_07_0.IFO 16KB
    VTS_07_1.VOB 694.942KB
    Target:
    I want to obtain a DVD which
    - plays back all video in a continuous stream without necessity to refer back to the DVD's menu for selection of next
    - is flagged correctly in 16:9 aspect ratio
    Chapter selection would be nice to have/nice to maintain as already prevailing, but is not a priority.
    Tools:
    I have IfoEdit v0.971 and PgcEdit v 8.6.
    Actually, I tried resetting aspect ratio from 4:3 to 16:9 in PgcEdit which it did correctly, however - only for first chapter. It also backed up the not crossreferenced other chapters to backup folder. I deleted this useless result.
    Would appreciate any advice as to how fix, starting from initial situation. Thanks.
    Apr 2004
    Miskatonic U
    Every titleset IFO will will have an aspect ratio flag, so every one of them will have to be changes if they are wrong. I find IFOEdit simplest for this, but PGCEdit can do it just as well.
    Never tried to make a play all with PGCEdit, as I author with DLP which can do this easily.
    Read my blog here.
