HI
I wonder what is the best alternative to Nero to make CD ( possibly freeware and ....easy!!)
thanks
Results 1 to 13 of 13
ImgBurn for data CDs and all DVDs
For audio CDs, this is good: http://www.burrrn.net/?page_id=4 -
For audio cds you can try CdburnerXp, for CD/DVD Data/DVD Video i also suggest ImgBurn
I love it when a plan comes together! -
If by "make CD" you mean to make audio CDs, there's no reason to not use Nero. I suggest using ImgBurn as much as anybody here, but honestly for audio CDs the truth is that Nero is fine. It's also OK for data discs and burning image files. Our big objection is using Nero to make VCD/SVCD/DVD and in those specific cases it's better not to use Nero. There are valid technical reasons for not using Nero to make VCD/SVCD/DVD but the explanation is long so I'll not post it here.
nero is fine for audio cds but there are free options, cdburnerxp is a 3 meg free download with a " simple and clean gui", that does the same thing as nero. Why should i pay for nero when i get the same for free?
Cdburnerxp:
audio/data cds
data/video dvdsI love it when a plan comes together! -
ImgBurn also burns audio CD's from various sources.
http://forum.imgburn.com/index.php?showtopic=5555 -
Same question recently asked and answered here: I need to replace Nero recommendations?
Has a nice detailed answer.Want my help? Ask here! (not via PM!)
Nero's okay for audio CDs, nothing else, IMO.
You need to keep it on a short leash, though. I use the custom install for Nero 7 Essentials (came with a burner) and select only the core app and StartSmart. Nevertheless, it installs Nero Scout, a really evil accessory that's turned on by default.
Turn off Nero Scout and disable NM Indexing in Services. Unless you like having your hard drives thrash constantly.Pull! Bang! Darn!
software alternative to nero to put a dvd on my HW
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 06:36 -
Free alternative to Nero
By ddongle in forum Newbie / General discussionsReplies: 4Last Post: 23rd Dec 2009, 13:19 -
alternative to nero
By m-man in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2009, 10:57 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 10:19 -
ConvertXtoDVD Alternative?
By foxbox in forum Video ConversionReplies: 29Last Post: 10th Jul 2007, 17:13
