Hi
Has anyone used the batch render script in Vegas pro 8? I can't seem to set it up for a multiple batch render.
Thanks in advance
Hi gunslinger
have you ever run across any literature on this script option? I can't see it in the "help"
Thanks -
I am still using Vegas 7 at home, and there isn't any documentation for the scripts in the help file. The Batch Render script in 6 and 7 is only there to batch elementary streams or to create multiple format outputs of a single timeline (e.g. render the streams for DVD authoring, as well as an iPod ready download version), not for batching multiple timeline renders.
Read my blog here.
thanks for the reply gunslinger
Have you ever run across a script for seperate multi clip rendering? -
Multi-clip, or multi-project ? There are scripts around to render different regions of the timeline, similar to the script in sound forge. I haven't seen one for batch rendering projects though.
Read my blog here.
Hi , I'd just want to throw some info here in case it helps. If in Vegas 8 (I believe it works in prior versions) you want to select given blocks or segments of the timeline, it is possible to batch render them in one full render click. Basically mark each of the regions you want to batch render and once they're selected click R, to create a Region. Do this for every single piece of the timeline you want to render. Once this is done go to TOOLS, then Scripting, then choose Batch mode. In the pop up menu that pops out choose the format or formats (if you want to export to multiple formats) that you want your 'regions' exported to. Then at the bottom make sure you mark the option 'Regions'. Then accept and Vegas will start the batch render process.
Thanks maclovio
There is also a free script from Jetdv that even assigns the region name to the batch rendered clips.....
http://www.jetdv.com/scripts/BatchRender-Regions.cs
how to render HD quality with vegas pro
By buffaloboyy in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2011, 10:51 -
Vegas Pro 9e - Can't render AC3
By stantheman1976 in forum AudioReplies: 6Last Post: 24th Nov 2010, 17:59 -
Sony Vegas Pro 9: Batch Render Clips Separated by Markers
By mltwitz in forum EditingReplies: 0Last Post: 5th Apr 2010, 15:41 -
Vegas Batch Render?
By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 02:42 -
how do I batch render in vegas 7
By Jorge in forum Video ConversionReplies: 1Last Post: 25th Aug 2007, 19:02
