Hey everyone. So, I have a few .avi files that use the AC3 audio codec, and I am trying to burn them to a dvd using nero vision. The problem is that after nero goes through and converts the video and burns it to the dvd, I try to play it in my dvd player, but there is no audio.
When I try to play the avi files on my computer, I get the same no audio problem when trying to play them with windows media player, but they work fine if I use VLC media player. It's like nero and WMP don't see that there is any audio there, which I guess is why it wont put it on the dvd.
I am pretty new to this, so I spent a while googling, but didn't come up with anything that was very helpful. Hopefully you folks will be able to get this all sorted. Thanks for any help you can offer!
-jon
Convert MKV to DVD video for burning with Nero Vision
By OreRockOn in forum Video ConversionReplies: 3Last Post: 4th Jan 2010, 11:42 -
Converting DIVX .AVI Files to DVD using Nero Vision 8 and 9.
By nnhood in forum Authoring (DVD)Replies: 2Last Post: 26th Jun 2009, 20:09 -
avi to dvd using nero vision 4 not working
By stevencg in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jan 2009, 22:19 -
Want to keep 5.1 but Nero Vision 4 DVD jitters from AVI file
By CoachSerpico in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 08:21 -
Nero Vision - preview screen when burning
By bigj7489 in forum Authoring (DVD)Replies: 0Last Post: 15th May 2008, 13:57
