I've been spending the past 2 weeks ripping my DVD library to AVI (X.264 / AC3 5.1). It seems that all of the files share the same thing, the volume is much lower than the original. I have to crank the volume all the way up to hear. The volume boost is enabled by default in FairUse settings. I'm a little disappointed, especially since I've spent so much time on this.
Any idea how to repair this without sacrificing any of the original audio quality? Should I be doing anything special as I go forward using FairUse?
Thanks.
Fairuse wizard will just copy the ac3 audio if you make an avi with ac3 audio. No conversion.
Have you tried use the ac3 filter as ac3 decoder?
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 12:37 -
Fairuse Wizard
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 20th Feb 2010, 05:38 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 13:34 -
Adjust audio volume with FairUse Wizard or later
By 2dpikke in forum DVD RippingReplies: 5Last Post: 5th Jul 2007, 23:40
