I want to save some VCRs on my hard disk and convert them to DVD. I've got a tv/video capture card installed and the necessary grabber device GrabBee x+ deluxe) with all the drivers installed and updated. I've tried 4 or 5 apps (Grabbee software, Nero, Blaze media and various freewares I've found) but none of them can actually read the signal from the capture device (I can't see anything on the preview screen when I play the tape so when I try and record it just comes out blank) The video capture card works (I have recorded some analog TV) and I've checked that the VCR output is working.
Some suggestions would be really appreciated![]()
Use the Analog TV source on the same input on the capture card that you are connecting the VCR to, whether composite or S-video. Then test the same output on the VCR on the TV. Once you have verified both the card input and the VCR output, then it is most likely Macrovision.
Discussion of Macrovision removal is not allowed on these boards.
Macrovision is carried on Line 21 of the video signal.
Closed captions are also carried on Line 21 of the video signal.
There are various devices designed to stabilize a video signal for recording, such as the Sima Copy Master, or SCM. Be aware that using an SCM will completely remove all Closed Captions from the video signal. -
Thanks for your quick reply. Well it turns out that I'm a newbie idiot. The scart plug of the grabber had an input-output switch, which was switched to input! Working fine now.
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53 -
Does CW do something to their HDTV signal?
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 9th Jun 2008, 08:21 -
Looking for a device to output signal as second (or mirrored) monitor to TV
By ViRaL1 in forum Off topicReplies: 0Last Post: 29th Aug 2007, 11:33
