I use TMPGenc xpress to convert rmvb to mpg and then with TMPGenc author to dvd.
Clip 1 & 2 is 29.97 fps while clip 3 , 4 & 5 is 25 fps.
I use TMPGenc xpress to convert it with its fps to mpg.
Is it the correct fps or I need to convert it to same fps?
After convertion, I use TMPGenc author to convert it dvd.
What fps should I use? 29.97 or 25?
Some authoring packages allows you to mix 29.97 and 25fps (like dvd-lab and guifordvdauthor) but it may not work on all dvd players. But if you want to use tmpgenc dvd author and make a compliant dvd then must you convert to same fps.
If I convert to same 25 fps from 29.97, any disadvantage compare to existing 29.97 fps file? Like smooth and sound of the video?
Will it depend on me to convert from 25 to 29.97 or 29.97 to 25?
how can i add multiple video clips to play as one dvd???
By Banleno007 in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 10:53 -
Why do I have multiple files when I convert HD to SD using Tmpgenc??
By Endoking01 in forum Newbie / General discussionsReplies: 12Last Post: 9th Jun 2010, 22:43 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 07:12 -
VEGAS PRO - How to SELECT & DRAG multiple clips at once
By reniet in forum EditingReplies: 3Last Post: 19th Dec 2008, 21:22 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
