  1. Member joelson's Avatar
    May 2004
    Brazil
    Hi all!
    I'm trying to correct a video that I've received. The person who recorded it rotated 90 degrees during the footage. I tried to split it into 2 parts with Virtualdub, corrected the wrong part with the Filter/Rotate 90º feature. However, it didn't let me join back the parts, as they have different sizes.
    How can I do this? Is there any other software that eases that job for me?
    Thanks in advance!
    Best regards,
    Joelson.
    Different sizes as video frame size/resolution? Then resize to same size.
  3. Member joelson's Avatar
    May 2004
    Brazil
    Fine. How can I perform that?
    Best regards,
    Joelson.
    Filter->Resize in Virtualdub
  5. Member joelson's Avatar
    May 2004
    Brazil
    I did that, but the image stretches. Is there a way to resize and do anything not to stretch, like adding black stripes? Does VirtualDub do that?
    Best regards,
    Joelson.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The resize filter lets you do that as well. Have a play with the letterbox options.
    Read my blog here.
  7. Member joelson's Avatar
    May 2004
    Brazil
    YOU ARE GENIOUS!!!
    Thank you! It worked perfectly!
    Best regards,
    Joelson.
