Hi Guys...
This is my first post, i find this forum is very helpful to me... :P
My Q's is :-
* I hve downloaded blurayrip movie in mkv format (size = 7.4gb approx), i want it to burn on DVD to watch on my TV.
* If i compress 7.4gb to 4.3gb to fit on DVD5, it will losse its quality so i decided to convert it to DVD9 using VSOConvertxtoDVD,But last time i burned to dvd9 using Nero 7 after that i can't play it on my DVD... so this time i decide to get help form you guys...
* My DVD supports MP4 and DIVX so...if i convert the above mkv files to mp4 / divx format..am i going to get the same quality ?
* Please suggest me ..i should convert it to DVD9 or DIVX formate ?
John
Nero is an average burning application for DVD5, and useless for DVD9.
Use Imgburn to burn the disc, and use Verbatim DVD +R DL discs. Anything else is asking for coasters.
The restrictions on bitrate means that in all likelihood you will get a lower quality Divx encoded file than you would if you encode to DVD9. Personally, I would use FAVC because I believe HCEnc is a better quality encoder than ConvertXtoDVD.Read my blog here.
Or if you want to make an avi divx/xvid then you can try xvid4psp, open the mkv, choose AVI Hardware under format, change the resolution to 676 x XXX under Video->Resolution and convert. It will probably take ages to convert and with similar quality as dvd so it's probably not worth it.....
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 08:55 -
Dvd9 to mkv help
By HACKJACK in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2011, 01:23 -
MKV to DVD9
By juicemaker in forum Video ConversionReplies: 5Last Post: 24th Dec 2009, 15:28 -
Xenon MKV Help Pls
By sikstik in forum Video ConversionReplies: 5Last Post: 13th Jun 2009, 13:50 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 05:17
