Hi,
Does any of you knows why my Philips PET 702P is unable to play DVD Media but plays VCDs and Audio CDs?
I tried resetting to factory default but to no avail. Please help. Thanks!
DVD media with copied dvd-videos?
What kind of dvd media? Commercial dvds? Dvd-r, dvd-rw, dvd+r,dvd+rw, etc?
If no DVDs at all the dvd reader laser might be corrupt. -
Before, I was able to play most DVD Media. But suddenly, after I mistakenly input DVD Data file, My player is now unable to read DVD Media. I tried VCD Files and it is working. If the DVD Reader laser might be corrupted, how can i fix it? Should I replace the lens? Thanks for prompt response mr. admin.Originally Posted by Baldrick
You can't break your player by trying to make it play DVD data files. DVD players use different lasers to read CD and DVD media, so when this happens it almost always means that there is a problem with the DVD laser. You can try cleaning the lens but if that doesn't work it will require a repair or you'll have to replace the player.
Unable to play certain mkv files on Viewsonic Media Player(VMP70)
By bappida69 in forum Newbie / General discussionsReplies: 5Last Post: 18th Oct 2011, 17:40 -
Philips PET 705
By Blue Jay in forum Portable VideoReplies: 4Last Post: 21st Jul 2008, 16:59 -
service mode portable dvd player pet 705 philips
By martuneac in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2008, 14:10 -
Repairing the DVD Drive -- Philips PET 1000 Portable DVD Player
By ORSteve in forum Portable VideoReplies: 1Last Post: 13th Aug 2007, 13:45 -
By ORSteve in forum MediaReplies: 0Last Post: 3rd Aug 2007, 21:09
