MY ORIGINAL DRIVER AND SOFTWARE FOR WINFAST PVR2 IS CORRUPT SO I DOWNLOADED THE DRIVER AND SOFTWARE FROM LEADTEK, BUT THE CURRENT SOFTWARE IS WINFAST PVR AND NOT PVR2, PROBABLY BECAUSE I COULD NOT FIND THE EXACTLY MATCHING FILES. WHEN RECORDING WITH THIS CONFIGURATION FROM TV MANUALLY THE DEVICE WORKS, BUT WHEN THE PROGRAM SCHEDULE IS APPLIED IT DOES NOT RECORD AT ALL. CAN YOU HELP PLEASE?
	http://www.leadtek.com.tw/eng/support/download.asp?license=y&downlineid=232&downline=W...P%20DTV200%20H is the page for the latest drivers and Winfast PVR2
 You should also get your keyboard checked - the shift appears to be broken. In forum terms, this is considered shouting, and rather rude.Read my blog here.
	Thank-you for your help. After having found the correct driver and software I do get the TV program but only via the CVBS action and not the digital TV channels, where I get a blue screen. When recording with the CVBS action there is severe background noise which masks the audio. Can you help me to resolve these problems? Thanks in advance for any aid...
	My set up seems to be OK . Maybe the problem is in the comp itself. Thanks.
  transferring a file to external hard drive not workingBy angryassdrummer in forum ComputerReplies: 5Last Post: 15th Apr 2011, 23:27
  Question about Winfast card & Hauppauge software ??By VEBouto in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 11:03
  liteon dx 401 external blu ray, tsremux not working neither bdinfoBy lodwales in forum Blu-ray RippingReplies: 2Last Post: 25th Jan 2009, 06:38
  Can a pci esata card be both internal and external simultaneously?By yoda313 in forum ComputerReplies: 9Last Post: 1st Dec 2008, 15:45
  Problem with WINFAST TV2000 XP Expert tv capture card.By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
