Results 1 to 30 of 36
  1. When I go to the cmd prompt (Start>Run>type cmd) and type help, I just found by chance on my computer Del is the command for delete, but if you go to an official Microsoft website, it says the Delete is the command for delete.
    My question is, why does my xp computer use a different syntax than what is listed on Microsoft websites?
    Also, what other commands (or syntax) can I expect to be different than what is listed on Microsoft websites? It certainly is difficult if I want to learn dos if my computer is using a different syntax than what I can find on websites.
    Also I have another question. It seems dos is used either when Windows is running normally (command prompt) or in the Windows Safe command prompt mode. However, is it possible to use dos, entirely independent of Windows? If so, what is the way to access the dos prompt? For example, is there a simple(one that doesn't require the original Windows CD) program I can burn to a CD and when I insert the CD, I can use dos to access my files?
    "del filename.ext" is correct.
    I don't ever recall using "delete". I'd be surprised if that worked. Maybe it's something new in the psuedo-DOS that is now run from Windows (It's not really "real" DOS anymore). The Windows kernel controls the OS in an NT system (NT4, 2000, XP, Vista, etc). There is no more "DOS".
  3. Banned
    Jun 2007
    UNREACHABLE
    "Del" or "erase" is the correct name for the command.
    Probably MS keeps employing webmasters who swallow too many tequilas per day.
    You could use a Windows 98/ME emergency boot floppy or CD --- BUT
    this would also require an NTFS-capable "add-on" for accessing the HDD(s).
    That's why I still use FAT-32 on my very-old Pentium IV.
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    What page are you referring to?
    Not this one, anyway: http://technet.microsoft.com/en-us/library/cc771049.aspx
    Originally Posted by Microsoft
    Del
    Updated: September 28, 2007
    Deletes one or more files. This command is the same as the erase command.
    http://www.bootdisk.com/bootdisk.htm
    http://www.allbootdisks.com/
    Or you might use a bootable Linux CD, eg from
    http://www.sysresccd.org/
    or http://www.knopper.net/knoppix/index-en.html
    If your drives are formatted NTSF, check the specs to see if the boot disk can read NTSF -- some can read, but not write reliably: http://www.bootdisk.com/ntfs.htm
  5. Official Microsoft website:
    http://support.microsoft.com/kb/307545
    And a dos command from that website:
    delete c:\windows\system32\config\default
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Those are not "DOS" commands.
    That's the Recovery Console.
    See http://support.microsoft.com/kb/314058
    Available commands within Windows Recovery Console
    The following commands are available within the Windows Recovery Console. The commands are not case-sensitive.
       attrib    del        fixboot   more     set
       batch     delete     fixmbr    mkdir    systemroot
       bootcfg   dir        format    more     type
       cd        disable    help      net
       chdir     diskpart   listsvc   rd
       chkdsk    enable     logon     ren
       cls       exit       map       rename
       copy      expand     md        rmdir
    Notice it has both "del" and "delete".
    Anyway, this is not the command line environment (mimicking DOS) you get from "cmd", though obviously many of the commands are similar.
  7. It's simply an abbreviation, no difference and no error. These have always been there.
    "DOS" used to be the OS that allowed Windows to run as a program. It's now the other way around.
    "DOS" as a booted OS can not natively read or write an NTFS drive.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Oh really? Did you try it?
    Doesn't work for me.
    P:\DVD>delete comedy.txt.bak
    'delete' is not recognized as an internal or external command,
    operable program or batch file.
  9. Delete in the recovery console is used to delete lines in the config.txt file.
    Its ONLY used in the recovery console . You could try the dos command
    DEL *.*
    You get a cute little animation, an easter egg from the msoft pgrmrs, probably.
    Two really, really cute puppies..... aw Diddums....
    The electronic components of the power part adopted a lot of Rubycons.
  10. If I remember correctly, DOS could use both. DELETE appears to have been dropped somewhere along the evolutionary path.
  11. Thanks for the info on the difference between the commands for Recovery Console and commands for dos. On my computer for dos command prompt, Delete has no effect. Only del can be used.
    All this topic came about because I got a autorun/pif virus that attacked my c,d and e drive. I restored the c drive but the virus remained on the d, e drive and then reinfected the c drive. The virus on the d, e drive could not be deleted though Windows. I believe the virus was deleted in Windows Safe mode command prompt by first eliminating the hidden and system file attributes:
    attrib -s -h autorun.exe
    and then deleting:
    del autorun.exe
    I suppose if I lived in the US, someone would charge $200 to spend the 2 minutes to do that.
    I'm not sure if the above commands are right because I was not the one who fixed the computer. At any rate, I am just trying to learn the methods to eliminate these kinds of virus by myself. One thing that I think was very helpful was to turn off the autorun:
    http://nick.brown.free.fr/blog/2007/10/memory-stick-worms
    I am curious, what other kinds of serious virus could withstand restoring the c drive? This is the first time that restoring the c drive did not solve the problem. I am thinking there might be a kind of virus that cannot be deleted in Windows safe mode command prompt. Then I wouldn't know what to do. Any ideas?
  12. Well, I'll be damned, it doesn't work, DELETE that is. Worked in DOS, for one I always use the short version and I guess don't really see the big deal. CMD or Command, ChDir or CD, there are differences in what runs but one or the other always does.
    Now, Jim, I guess you don't read really well. Told you before, the attrib command used is "attrib -r -s -h" followed by either a *.* or a specific file name. You often need to do this from a clean boot disk or a Linux disk with an NTFS reader.
    There are lots of viruses that cannot be deleted from a Windoes command prompt. There are some that will prevent you from switching to the directory. Hence the need for a clean boot disk. The virus must be prevented from running, which it often does from a system32 DLL or as a service.
    A virus that can't be removed by a complete C: image restore is quite simply a virus that had someplace else to hide.
    The $75 to $150 you would pay to clean these is not for the 2 or 20 minutes spent, it is for knowing what needs to be done during that time. Like cleaning the Temp directories, scanning for invalid DLL files, checking for autorun, lots of things. Finding a bad DLL is like porn, not sure I could explain it to you other than I know one when I see one. Simple things are to look for recent dates and names like "yyxxgg.dll".
    Another thing you might be paying for is to be told that if you walk down back alleys in bad sections of town, you should not be surprised when you end up with dog crap on your shoes.
  13. This is turning out to be difficult. I checked out the above links for a boot disk and it seems that they require a floppy drive, or the original xp disk, which I don't have. I don't have a floppy drive. I think there is some aspect of this topic that is very confusing. There is one site:
    http://www.free-av.com/en/tools/11/avira_ntfs4dos_personal.html
    (see screenshot)
    that seems to be what I need.
    I am looking for free software to:
    I need a cd that when I insert the cd into the xp computer and turn it on, the computer will boot into dos and then I can delete an unwanted file on an ntfs partition that cannot be deleted in Windows Safe mode.
    However, when I look at the documentation for the software,
    http://www.free-av.com/documents/products/pdf/en/man_avira_ntfs4dos_pers_en.pdf
    it says I need to make a floppy disk. Can you take a look at the documentation and tell me if there is a way to use this
    software to make a cd (not a floppy) that boots to ntfs read/write dos.
    I have a dos program already installed on my computer (some Chinese thing called maxdos) but I can only read /write my
    fat32 partition, not the ntfs partition.
  14. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You can put any of the floppy images on a CD and boot from that.
    Eg, ImgBurn: see Advanced/Bootable disk.
    And in my previous post I linked many bootable Linux CDs.
    I begin to wonder why I bother to post when you don't read the messages that answer your questions.
  15. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    RabidDog wrote
    ....You could try the dos command
    DEL *.*
    That's not nice. You are
    I can
    But the guy who delected a whole directory full of important files won't laugh.
  16. I have xp, not Linux on my computer. I will attempt to figure out how to modify the method in the ntfs4dos documents to create a cd. Should I make the floppy first and then transfer the image to a cd, or is possible to make the cd directly?
  17. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    If you just need to delete or copy files, Linux (Knoppix, Ubuntu, etc, etc) can do that.
    That's why I recommended it.
    Actually, most bootable CDs you find online are Linux based.
    For one thing, there are no copyright issues as with hacked versions of Windows.
  18. Ok, I will download the free live Ubuntu, try to burn to cd, and see if I can run my computer off the cd live (I don't want to install another operating system) and then try to delete a hidden/system file off the D ntsf partition. If I am successful to do that, then I should be able to delete any virus off my D, E partition. Ghost restore will take care of the C partition.
  19. In the meanwhile (while Ubunto is downloading) , I looked at the Ultimatebootcd forum to see if that software would allow me to delete a hidden/system file on an ntfs partition, but according to the forums, most people cannot do that. (See screenshot.)
    So I think that software won't work for me, although I haven't actually tried it yet.
  20. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I'm unsure about ultimateboot cd but as far as Ubuntu goes the latest version 8.04 can read/write and delete files from ntfs drives perfectly fine from the live cd. No installation necessary.
    Donadagohvi (Cherokee for "Until we meet again")
  21. I'm unsure about ultimateboot cd but as far as Ubuntu goes the latest version 8.04 can read/write and delete files from ntfs drives perfectly fine from the live cd. No installation necessary.
    I appreciate the simple reply, right to the point.
    (Ubunto still downloading.)
  22. It is not clear why you ask this question, no one uses DOS in these days except IT people who can type very fast and write scripts or small programs on the fly. You can boot into safemode command prompt only and it is kinda like DOS but Operating system is windows. You can boot into DOS but if your hard drive is NTFS you cannot access the hard drive. You have to use Dr DOS or windows DOS or something like that. But the easiest way is to download Ubuntu and burn it to a disc it is a linux it can boot by cd and you can access your hard drive even in demo mode and everything works in demo mode. Ubuntu does not require installation to make the computer to work and it detects your sound USB everything. It is free and very nice you may get hooked to it.
  23. Sorry I jumped to conclusion.. , I didn't read all the responses. If you think you have virus, download the dos version of anti-virus from their website many have free versions like Trendmicro, and boot into safe mode and run it to clean it. If you have a rootkit virus or some trojan maybe impossible to clean because it goes into Kernel and can't be seen or detected not even by above average knowledge. Find all the drivers and software that you have backup your data, Format the hard drive and reinstall that is the only sure way and you computer will perform like the first day it was installed.
  24. As I am waiting for my Ubunto to finish downloading, I would like to ask a question about this so called "kernal" that you mentioned. My idea to deal with viruses/ trojans etc is to restore the C drive from Ghost DVD and then use Ubunto to delete viruses/trojans etc from the D and E drive. I just have a few files on my D, E drive (movies, songs, install files) . So I know immediately if there is a file that should not be there. Are you saying this "kernal" thing can be on the D/E drive and be invisible to Windows or Ubunto file explorer? I don't care what kind of kernals/viruses/ trojans/worms are on the C drive because it will be wiped clean and restored in 20 minutes by the Ghost restore DVD.
  25. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    The kernel is the process that runs everything else. Stopping it shuts down the system. If it's corrupted, you can't trust it, or any program it controls, which is all of them, to delete or even show you what's what. So you need an independent program to access the hard disk, such as a bootable floppy or CD with its own operating system, to clean it up.
    If you have an evil kernel, it can hide things anywhere. But if it's not running, you can see them and delete them.
    Look out for "autorun.*" files, which Windows will helpfully run automatically when it sees them. That's one way of getting (re)infected.
  26. Once you boot Windows, whether standard, Safe Mode, or to a "DOS" prompt, you get the Windows system with all that it includes, which may have been modified by a virus. Far more than just the "kernal" in involved.
    If infected, sometimes the ONLY way to remove the infection is NOT to boot Windows, or at least not the Windows on that particular drive.
    The UltimateBootCD, or at least the last one I DL'd, did not include an NTFS reader, but there were fairly easy instructions to add one to it. I used NTFS4DOS, which works fine.
    Once you boot a CLEAN operating system, with no connections to files on your current drives, the virus is inactive. ALL files are, or can be, visible and deleted. This is where the attrib command can come into play.
    Haven't tried the latest Ubuntu yet, but it should work as well. A boot CD which can read and delete NTFS files is an essential anti-virus tool.
  27. I used NTFS4DOS, which works fine.
    I'm wondering if you could upload that NTFS4DOS iso so I could just download and burn it to a cd and see if I can use it to delete a file on my ntfs partition.
  28. You have to build it into the Ultimate Boot CD.
    NTFS4DOS by itself won't do the job, it must be installed onto a boot disk.
    There were complete instructions on how to do this on the UBCD website, it was not hard at all. You just add it as a user-defined program.
    If you have the Ubuntu CD, that should work, am about to test that myself. Reputable posters have said so, have you downloaded that and tried it?
  29. Where I am, I am having difficulty downloading large files. I have ordered a disk by snail mail.
    Are you saying that a CD that will boot into read/write ntfs dos is computer specific, that is, 1 CD can't be used for all xp computers? Otherwise, why can't you post the iso?
    Also, according to forum postings, Ubunto still requires some finesse to get it to delete ntfs files when xp Windows has crashed. The following from the site:
    http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-y...dows-computer/
    has the strangest English wording I have seen in a while, and I cannot follow it.
    Now comes the tricky part. You'll need to type out a command very similar to this one, but you'll need to replace /dev/sda1 with what you see in that message box we showed you [below]. This command tells Ubuntu to use the ntfs-3g driver, and force mount even if there is a problem.
    mount -t ntfs-3g /dev/sda1 /media/disk -o force
