Hi,
I have many VCD's that have dual-audio that I want to convert it to Divx-AVI with only one of the audio in it, can someone HELP?
Alberto
Results 1 to 11 of 11
I guess they have different audio in left and right stereo channels? or?
Yes, they have two language, one on the left channel and the other is on the right channel.
I have not seen any converter that fixes this automatically so I guess you have to extract the audio(like with virtualdub, open .dat from vcd, file->save audio) and use an audio editor like audacity and remove one channel and save as a wav mono audio. Then use that audio file in the converter(like virtualdub again, open .dat from vcd, audio->source audio and choose the video file, video->compression choose avi xvid, file->save avi).
Maybe someone else knows an easier way for this though. -
It seems easier yes.
So in Virtualdub
Open .dat from vcd
Audio->Full processing
Audio->Use advanced filtering
Audio->Filters and the settings by jagabo above
Audio->Compression and choose mp3 (install lame mp3 acm if you can't see any mp3)
Video->Compression choose divx or xvid (install the divx codec or the xvid codec if you can't see any divx or xvid)
File->Save avi
Done! -
I have follow exactly the steps but when I save it to AVI, it gives me an error "Error initializing audio stream compression: The audio codec cannot compress the source audio to the desired format." I try various formats for the audio but it gives me the same error.
If you don't add any audio filters can you convert then?
Use the Audio Conversion section to set the audio paramters to 44.1 or 48 KHz, 16 bit, stereo, high quality. Select the compression after setting the audio parameters.
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Dual Audio AVI
By headshotpro in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2008, 07:09
