Hi,
My wife purchased a Pandigital 11" Picture Frame that does slideshows of digital pictures and also plays video (kind of). The catch, the only video supported on this POS is "Motion JPEG 3.2.4". Does anyone know of a conversion tool that converts AVI, etc. to "Motion JPEG 3.2.4"?
In fairness, I love the device, but not happy when the False Advertising states it supports "most" video protocols.
Brian
I don't know about the "3.2.4" part but AviDemux can save as MJPEG AVI. VirtualDub can convert to MJPEG AVI if you have a VFW MJPEG codec installed (ffdshow includes one).
This ad says "Video Formats Supported: M-JPEG, AVI". AVI is non descriptive.Originally Posted by srt842
http://www.drugstore.com/products/prod.asp?pid=170363&catid=110969&aid=337953&aparam=p...LAID=107322321
Newer models spec only "AVI".
http://www.pandigital.net/galleriesRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks Jagabo!! I'll give them a try and see if I make any progress. I'll report back with my findings.
MJPEG 3.2.4 appears to be a particular MJPEG codec from MainConcept:
http://www.free-codecs.com/download/Motion_JPEG_Codec.htm
AviDemux, ffdshow, or PicVideo MJPEG codec should work fine.
keepvid.com and their new "high quality" download tool
By snafubaby in forum Video Streaming DownloadingReplies: 24Last Post: 8th Dec 2010, 20:19 -
VideoStudio 8...will it support "motion jpeg"?
By utamav91 in forum EditingReplies: 0Last Post: 22nd Nov 2010, 23:35 -
Ask for Tip of a tool just like "Blu-ray to DVD II Pro"
By jjulio1 in forum Blu-ray RippingReplies: 0Last Post: 5th Aug 2010, 08:17 -
Problems with "Motion Lines" in SOME ISO to AVI conversions using
By cplevel42 in forum DVD RippingReplies: 8Last Post: 8th Oct 2009, 17:30 -
Problem.. DGIndex reports "motion code error" :cry:
By _migz_ in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 06:09
