    Apr 2001
    Portugal
    How can i convert mov to VCD in *.mov files with audio protection.
  2. go straight to tmpgenc, load up a vcd template and encode.
    If you encounter problems with the encode, you may have to convert the file to avi, then encode to vcd.
    follow this thread for more info..
    http://www.vcdhelp.com/phpBB/viewtopic.php?topic=48601&forum=3
    ZtR
  3. Get the QT Plugin (from this site) and put it in your tmpgenc directory and have Quicktime 4.x installed on your machine NOT 5.x
    Then convert like normal.
    I get no sound if i have QT5 installed.
