I have a Leadtek Winfast PVR 3000 Deluxe TV-Tuner that connects to the line-level analog input (for CD-IN/TV Tuner): CD-In, Aux-In (4-pin header) on the Motherboard’s built sound chip.
I recently bought a CREATIVE SOUND BLASTER X-FI TITANIUM FATAL1TY PRO (PCI-Express) and to my surprise I noticed that it has no analog CD-In 4-pin header to connect my TV-Tuner!
So how am I supposed to record audio if I cannot connect the TV-Tuner to the sound blaster?!
I don’t think I’ll be able to enable both the sound blaster & the built-in motherboard sound chip in order to connect the TV-Tuner, they’ll conflict!
If there is no way, I’ll just have to change this card for an ASUS XONAR D2X/XDT/A.
Don’t the current Creative Sound Blaster cards feature an analog CD-In/TV-tuner 4-pin header any more?
Please any help will be highly appreciated!
Thanks in advance.
	nobody ever used the cd-in. it was for analog output of cd players. it was never needed for computers and has been sent to the dust bin. --
	OK, so I disabled the M/B sound chip and just created a custom CD-In 4-pin header cable. I cut the wire and connected a 3.5mm jack to the end and connected it to the line-input on the outside of the X-Fi sound card and it worked!
 However, after connecting it to the X-Fi Line-in, the audio from the TV-tuner sounds a bit lower than it did via the CD-In header of the motherboard’s built-in sound chip! (The Line-in volume is set to max). I would have expected something better from the CREATIVE SOUND BLASTER X-FI TITANIUM FATAL1TY PRO Line-in!
 How can I make the X-Fi Line-In sound higher?
 Interestingly enough, I was told that the Leadtek Winfast PVR 3000 Deluxe is one of the best hardware mpeg TV-Tuners around, so how come it does not pass the audio through the PCI bus but rather it needs a CD-In 4-pin header cable?
 Thanks in advance.
  WinFast PVR captures audio in PCM onlyBy jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 17:24
  winfast PVR -aviBy sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 13:13
  24 pin PSU for a 20 Pin motherboard; Doh!By Will Hay in forum ComputerReplies: 7Last Post: 5th Mar 2008, 12:02
  failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI SpliBy carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 13:46
  Winfast PVR Interlace capturing, is it possible?By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 22:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
