Ok, so I wanted real quick to cut, and drop some DV stream clips from
the last four SNL episodes of the Palin paraodies.
I opened the avis ( XVID encoded) in MPEGStreamclip, v. 1.9.2,
on a MBP with 1.5GB of Ram, running OSX 10.5.5, with
Perian 1.1.1 installed.
The first 17 minutes of the avi is loaded in the window, but
will not load anything past that.
From MpegStreamclip's Stream info:
Opening the file in Quicktime Pro 7.5.5, correctly shows the complete file,Duration: 0:17:34
Data Size: 142.47 MB
Bit Rate: 1.13 Mbps
Video Tracks:
Xvid, 624 × 352, 29.97 fps, 1.00 Mbps
Audio Tracks:
MPEG Layer-3 Audio stereo, 48 kHz, 128 kbps
Stream Files:
Saturday.Night.Live.S34E03.Anna.Faris.HDTV.XviD-XOXO.avi (142.47 MB)
and movie info says this:
Has anyone else seen this type of wierdness?
I've emailed squared5, but no answer as of yet......
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
do you have another QuickTime codec to decode Xvid?
MPSC avoids to use Perian (lot of bugs wih some codecs), so it does not load it if it's not necessary (if MPSC found another codec can handle the wrapper/codecs).
Maybe a non-activated codec in QuickTime (XVid component/DIvX/etc) was loaded by MPSC?
so, check your folders (~/Library/QuickTime/ and /Library/QuickTime/)
I don't have other idea
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
the only other one I have on this MBP is the default Toast 8 DIVX decoder/encoder.
I'll try moving that out and see what that does...."Everyone has to learn, so that they can one day teach."
Urban Mac User
MPEGStreamClip AVI issue
By low-fat-al in forum Video ConversionReplies: 19Last Post: 28th Jun 2012, 19:49 -
Re-Encoding 720p H.264 MKVs to 400p XviD AVIs?
By Kid Boruto in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 13:01 -
Simple Script to Prepare Your DivX/Xvid AVIs for Transcoding
By Soopafresh in forum Video ConversionReplies: 17Last Post: 13th Jul 2009, 21:30 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
Resizing XviD AVIs...
By takearushfan in forum Newbie / General discussionsReplies: 7Last Post: 20th May 2008, 11:27
