http://www.virus.gr/portal/en/content/2008-06%2C-1-21-june
Interesting results.
Reinforces my decision to dump Norton, then McAfee, then AVG, currently on Avira AntiVir.
I dumped Norton, McAfee, & AVG as well. Been using Defender Pro powered by Kaspersky, and have been very happy with it. -
I think if you're using any of the programs above 90%, just stick with what you're using. Any of them should provide adequate protection and from what I've seen, the rankings within that group can shift around on any given day for any given test by any given tester.
Buy My Books -
Interesting results, I always enjoy BitDefender 2008 ......
How many of these are AV only ? Most of the AV vendors are now cramming AS (Anti-Spyware) into their product, just as the AS vendors are cramming AV into theirs. I think these all-in-ones lessen your chances of getting the best solution for each. And then you probably can't stack more than one on the same system, without getting problematic clashing.Originally Posted by lordsmurfWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
Virtually every AV will have some anti-spyware component now. It's isn't an effort to go all-in-one. It's the result of the line between virus and spyware blurring. A lot of malicious code has elements of both virus and spyware in it now so a scanner has to be able to pick up both.
Get used to security suites being the norm; not only do they command higher subscription fees, but by integrating antivirus, antispyware, antispam, firewall, and more in some cases, the vendor eliminates competition. Sure, you can add a second opinion AV or ASW application and I believe it makes sense to do so, but it won't have the same level of real or perceived importance as what is chosen as the first line of defense. There are a lot of people who just don't want to be bothered with individual choices. The security suite promises all you will need to stay protected and eliminates the possibility of potential conflicts (if you believe the advertising).
anti-virus
By Willy5157 in forum ComputerReplies: 19Last Post: 14th Dec 2011, 10:13 -
Do you use Norton anti-virus or freeware of something else?
By beavereater in forum ComputerReplies: 26Last Post: 31st Jan 2011, 23:34 -
Free Anti-Virus Opinions
By HotDamn! in forum ComputerReplies: 19Last Post: 13th Jan 2010, 16:49 -
AVG Anti-Virus & Anti-Spyware V8.0 1User/2Year Small Box - Retail
By MJA in forum Off topicReplies: 3Last Post: 13th May 2009, 22:28 -
Norton Anti-Virus: I Think I Have Been Shafted
By Tom Saurus in forum ComputerReplies: 27Last Post: 21st May 2008, 19:11
