How do you tell TMPGenc to encode multiple (segmented) avi files? My guess would be to use batch but it isn't clear how you point it at the series of avi files.
Thanks,
jlee
Start out the usual way...
1. Select your AVI source file in TMPEnc.
2. Select a WAV file (if applicable).
3. Load a template
4. Click File -> Save project. (Save it somewhere)
Now repeat. Save a project for each file you want to convert.
Once you have created a bunch of .tbr files (TMPGEnc projects),
click File -> Batch Encode.
Click the Add button to add your projects to the batch window.
Click RUN to start the batch.
FYI - I have had problems getting this to work. The first movie always encodes successfully, but when I return to my computer, TMPGEnc has closed (crashed I assume) and the second file in the batch is 0 bytes.
Let me know if you have the same issue. -
Worked like a charm for me. Not sure what I'm doing different from you. I just followed your instructions.
Thanks,
jlee
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Encoding a video with x264 from multiple files
By Virnec in forum LinuxReplies: 2Last Post: 22nd Feb 2010, 17:56 -
Help With Batch Encoding Multiple DV files to h.264 MP4's.
By mpalm887 in forum Video ConversionReplies: 2Last Post: 28th Jan 2010, 00:02 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
