Hello,
I tried re-encoding Bicentennial Man to XviD with AutoGK. The files have been copied off the DVD with DVD Decrypter. I can open the VOBs just fine with VLC and the movie plays without a problem but I ran into a rather odd issue.
When I pointed AutoGK at the IFO for the right PGC, I was told that there are multiple angles on this DVD. There were 2. I chose the first one, chose a target quality of 65%, and ripped to AVI leaving the settings on automatic. I was presented with an error saying "A field order transition was detected. You may need to use the Fix D2V tool to repair this stream. Refer to the DGIndex Users Manual for details."
I continued, letting it encode, and the resulting file has about 2 seconds of English, then that same 2 seconds in Spanish, then the next 2 seconds of the video in English, then that 2-second segment in Spanish...etc. I am wondering what caused this and how to fix it.
Thanks for helping out a AutoGK n00b.
JBot
Try pgc.NET ---> http://www.clonead.co.uk/
Here is what they say about pgc.NET:
"What is the importance of pgc.NET and PGC ripping? Why not just use the ripped vob files unprocessed for conversion? Well, an unprocessed vob file can contain more than you think, it may infact contain the same movie twice, different versions of it, a directors cut and a theatrical version, all in the same vob set, converting this would give unexpected results, while some movies may play fine, others will not. pgc.NET will extract the correct program chain giving a perfect source file for later AVI conversion."
I've used pgc.NET before and I think it is a good idea. You can then use any program like autoGK or avi.NET or XVID4PSP etc. to then convert to the XviD AVI format.
Another Angle on Video Compression
By mikesbytes in forum Newbie / General discussionsReplies: 7Last Post: 23rd Sep 2009, 10:59 -
2nd Angle plus subs?
By Jeikobu in forum MacReplies: 2Last Post: 18th Jul 2008, 08:25 -
Trouble with AutoGK...
By takearushfan in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2008, 08:58 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
Multi angle - dilemma
By flipzoso in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:36
