We could use some help on trying to establish and set up the publishing points needed to stream live from client to server. we are about at our wits end here. So if anyone can help us we would sure appreciate it. We have the adobe flash streaming media server 3.
On the left column of this site, select Guides. Then, under Author, select Baldrick. See if you can find helpful info there. (Your post is a bit non-specific, so it's hard to know the exact problem you're having.) Baldrick lives in Sweden, so you might have to wait a few hours for a response to this post.
I don't think you will find much help here. I have no experience with adobe flash products.
Doesn't adobe have some support forums? -
My bad, Baldrick. The memory must be getting faulty. Now I'm trying to rack my brain trying to figure out where I saw all the Flash info a couple of months back.
I thank you all anyway. Abode does have some online support but you cannot talk to anyone in person unless you pay an arm and a leg for their tech support. Its bad enough you have to pay an enormous rate for their programs and then more for the tech support too. I was just hoping someone here would have some knowledge with adobe.
Flash Media Encoder Delay When Streaming
By skillednerd in forum Video Streaming DownloadingReplies: 0Last Post: 12th Apr 2011, 17:44 -
Intermitent failure when streaming from MS Media Streaming Services
By OshiDaro in forum Video Streaming DownloadingReplies: 0Last Post: 8th Dec 2010, 07:10 -
Streaming a MP4 file from a site with flash
By Cazz in forum Video Streaming DownloadingReplies: 4Last Post: 5th May 2010, 14:21 -
Flash (H.264) vs WMV streaming
By kameel in forum Video Streaming DownloadingReplies: 1Last Post: 15th Dec 2008, 18:06 -
Problems Streaming Flash From Website
By yukon33 in forum Video Streaming DownloadingReplies: 3Last Post: 26th Aug 2008, 12:21
