Hello,
I,m sorry if this qeustion is asked somewhere, I tryed search and google. But I need some specifick info
I need to edit, a bleuscreen take into a existing dvd.
I ripped the dvd using DVDshrink,
Whats the highest qualty compression I can get when Im editing in AE? Its only a minute of video I need to edit so file size ist a problem, Im using a PC
And which conversion software is best to use for this.
Thx in advance,
Niels
Convert to uncompressed avi or dv-avi. Cut out the clip using dvd shrink in the reauthoring mode and then load the vob in for example avidemux or xvid4psp.
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 22:46 -
how to resize files with as little qualty loss as possible
By Ryan in forum Video ConversionReplies: 1Last Post: 9th May 2011, 14:40 -
Best Settings in VirtualDubMod to get high qualty video
By hzgg2 in forum EditingReplies: 9Last Post: 20th Jan 2009, 08:44 -
DVD > AVI or Mpeg fo re-edting then burning to DVD
By nutshellml in forum DVD RippingReplies: 7Last Post: 31st Mar 2008, 10:12 -
DVD creation/edting with VISTA
By ronkleim in forum Authoring (DVD)Replies: 6Last Post: 27th May 2007, 02:07
