Hi,
What is the best possible capturing setup using the radeon AIW, The aim is to archive all my old VHS tapes to DVD without losing quality is this possible?
I've used the TV tuner to capture before but i'm confused with some of the settings could someone point me to a guide or give me some help?
Much Appreciated
Littleady.
what is the vesion (multimedia) mmc7.1 ?
is it really Dvd or vcd (4.7GiG or 800 meg ? )
my best capture on mmc7.1 is
mpeg2
640x480
i frames only ( no p , no b )
8 Mbitrate or higher get good result
100% quality/motion
But : your next topic going to be
"how i fite 1 hour in 1 cd ?"
+ "how i convert the file to DVD ?"
your in the good site for these search -
Thanks for the reply.
I use MMC7.2!
Yeah its DVD-R-RW
Do I need to do anything with Interlace Because I'm capturing VHS?
I Sometimes get problems when capturing, the sound goes out of Sync when I convert it through tmpgENC????
Capturing PAL S-VHS-C - Advice very much appreciated
By Genu29 in forum Capturing and VCRReplies: 2Last Post: 31st Jan 2012, 07:02 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 21:08 -
Capturing VHS with Diamond AIW HD 3650PM
By justin81 in forum Capturing and VCRReplies: 1Last Post: 13th Jul 2009, 14:15 -
Capturing PAL-M VHS (Brazil) on UK system. Help!
By Killer3737 in forum Capturing and VCRReplies: 13Last Post: 11th Nov 2008, 10:24 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 16:11
