Hi, I've been using ffmpegx to convert my avi files to mpeg files to burn onto dvd's, but theres been one problem. I am also using the mac program "burn" to burn the dvd from the newly formatted file. I have been creating data disks with the burn program, and that splits the movie into multiple folders. The first folder(which comprises about the first hour) on every movie i have tried works perfectly, while the subsequent folders play video but have no audio. Just wondering if anybody out there knew how to fix this? Thanks
	So really you are creating a data DVD disc with MPEG files?
 At least it sounds as though this is what you are doing as opposed to a properly authored DVD Video disc (that should in turn work in any standard DVD player).
 Something doesn't add up in your description of what you are doing ... or why you are doing it in the way that you are doing it.
  Dvd's not playing on ps3By Sarah.J88 in forum Authoring (Blu-ray)Replies: 4Last Post: 8th May 2010, 05:07
  Burn .avi files as what type of dvd for playing on PS3By VenGeanCe in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2010, 18:56
  Playing multiple m2ts files on PS3 from a DVDBy dieselgg in forum Authoring (Blu-ray)Replies: 2Last Post: 20th Jun 2009, 10:47
  Problem playing an AVI file on PS3.By z.ee in forum Newbie / General discussionsReplies: 4Last Post: 13th Aug 2008, 16:58
  PS3 Video 9 - .AVI to PS3 - SettingsBy dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 14:48
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
