  1. Member Baggins's Avatar
    Oct 2008
    Hi, Newbie with my first post.
    I've recorded a TV Prog with my Sony DVD Recorder onto DVD+RW.
    Ripped it to my Laptop with DVD Shrink and am trying to convert it to DivX with StaxRip.
    Everything works fine, but the resulting .avi file, when played is stretched vertically.
    When I checked the StaxRip main screen & log file it shows the correct aspect ratio (4:3), but the width & height seem to be the wrong way round. See section of log below;
    Format : MPEG-PS
    File size : 958 MiB
    Duration : 41mn 9s
    Overal bit rate : 3255 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, Matrix : Standard
    Duration : 41mn 9s
    Bit rate mode : Constant
    Bit rate : 2773 Kbps
    Nominal bit rate : 9800 Kbps
    Width : 352 pixels
    Height : 576 pixels
    Display aspect ratio : 4/3[/b]
    Frame rate : 25.000 fps
    Standard : PAL
    Colorimetry : 4:2:0
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 1.933
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 41mn 9s
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Video delay : -400ms
    Menu
    Format : DVD-Video
    Any ideas as to why this is happening and how it can be overcome?
    Many thanks in advance
  2. Banned
    Freedonia
    Originally Posted by Baggins
    Width : 352 pixels
    Height : 576 pixels
    Your height is MUCH bigger than your width, which will result in exactly what you describe - vertical stretching. Maybe you need to reverse them, but do note that 57x352 is an aspect ratio of 16:9, not 4:3.
  3. Your source is half D1 PAL. Resize to a 4:3 frame size or use the MPEG4 DAR flags.
  4. Member Baggins's Avatar
    Oct 2008
    Thanks for your quick replies.
    jagabo, I'll check out the DAR Flags later, but why is the source half D1 PAL?
    Is it something to do with the Freeview DTV source or the DVD Recorder?
    Thanks.
  5. Banned
    Freedonia
    Damn it. I completely glossed over the DVD recorder bit in the original post because the subject was talking about Divx conversion. Anyway, half D1 recording is normal for DVD recorders. It's what they do when people record at low bit rates (ie. trying to get 3 or more hours on a single layer DVD). It's your DVD recorder doing this. Either use the MPEG4 DAR flags as Jagabo says (note that some DVD players that support Divx may not honor this flag) or record at a mode that puts only 1 or 2 hours on a DVD blank. I would suggest doing the latter as it's more likely to yield good results on a variety of playback devices.
  6. Even if you record at full D1 (720x576) you will have to resize or use DAR flags to get the right aspect ratio.
  7. Member Baggins's Avatar
    Oct 2008
    Thanks for your detailed answers, now I understand what's causing the problem.
  8. Or just resize it to a 1.33:1 ratio, such as 640x480, 576x432, 512x384, etc.
