Hey Everybody,
could somebody tell me how to encode NTSC film material to an NTSC DVD compliant .M2V?
The material is already 720x480 29.97i fps, with proper 3:2 telecined pattern. I've tried out a few variants so far in Procoder (Field order, Force Film mode etc.) with no luck. I've always ended up with ugly interlaced edges during playback. Factory-made NTSC DVDs are fine, mine is not.(I've authorized the DVD with muxman)
I use Procoder 1.5, I'd like to use this software to encode.
Thanks for any help in advance![]()
Results 1 to 9 of 9
wow, 1.5,
could hardly remember is there's avisynth support...
Procoder only added a dedicated ivtc filter at version 3.
still...
no reason to mess about with even that.
dgindex,
avisynth,
encode in procoder with a generic mpwg2 template to go to 23.976 progressive,
pulldown output in dgpulldown.
tripp"I'll give you five dollars if you let me throw a rock at you" -
Thank you for the response!Originally Posted by 45tripp
Procoder 1.5 has AviSynth support, actually the file I want to encode is an AviSynth file. I've done the 23.976p-->29.97i conversion myself in the script, so I can make it back to 23.976. (I don't what mpwg2 is, I hope I won't need that in this case.)
Will DGPullDown convert a 23.976p M2V file into a proper 3:2 29.97i M2V format? -
Yes.Will DGPullDown convert a 23.976p M2V file into a proper 3:2 29.97i M2V format?
Why on Earth would you do that? You get much greater encoder efficiency encoding for progressive 23.976fps.I've done the 23.976p-->29.97i conversion myself in the script -
Because I knew the DVD compliant format should be 29.97i in the end and I didn't know I have to do this conversion after the encoding.Originally Posted by manono
i know,Originally Posted by zee944
just had to think way back...
'mpwg2' is a typo
generic mpeg2 template,
if you select a standard dvd template you won't get 23.976
as a framerate on the pulldown menu.
or rather select the dvd template and then
change dvd to user defined so you can change framerate"I'll give you five dollars if you let me throw a rock at you" -
I've encoded the footage as 23.976p, and converted with DGPullDown into 29.97i. Seems fine (proper 3:2 pattern) except one thing: MuxMan says it's not perfectly DVD compliant:
Bitrate - avg: 5997114, min: 1602305 (lba 1643706), max: 7979220 (lba 1464308).
Shortest GOP has 2 fields, longest GOP has 38 fields.
Fields: 371358, VOBU: 9946, Sectors: 2267765.
Largest GOP of 38 fields exceeds DVD specification of 36, resulting DVD is non-standard.
13:58:49 Begin multiplex VMG.
13:58:49 End multiplex.
1 oddities detected, resulting DVD is non-standard. Check log for details
What should I do? -
Reencode using a lower GOP size. You use Procoder, right? I don't use it and thus have no idea how you choose GOPs, but you want a max GOP of 12 frames or 24 fields. The reason is that the GOP size increases after applying pulldown by a factor of 1.25. My guess is that you have it set up for 15 frames=30 fields.What should I do?
You're right! GOP was set to 15. I've set it to 12 and now it's fine.Originally Posted by manono
My first proper NTSC DVD. Thanks!
Pulldown? when Encoding a 29.970fps progressive AVI to NTSC DVD
By FulciLives in forum DVD RippingReplies: 5Last Post: 27th Feb 2012, 19:00 -
Procoder 3 authoring progressive NTSC
By telefunken in forum Authoring (DVD)Replies: 0Last Post: 24th Apr 2009, 01:09 -
encode interlaced material witth ffmepg to MPEG2 but get progressive output
By Massa in forum ffmpegX general discussionReplies: 9Last Post: 13th Jan 2009, 12:42 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
