In the Nerdout.com apex 660 forum they're working on extracting the new 9mm firmware from a newer apex 660 player. http://www.nerd-out.com./forum/list.php?f=17
could i update my 660-8mm with it possibly if it works for the 9mm?
thanks
THIS IS HARDCORE -
the update will work on 8mms and 8ams (ams can use mm firmware, but not viceversa)
Wholesale clubs like Sam's tend to have APEX's with upgradable firmwere because they get the older models.
The 9mm firmware is now available for download.
http://www.nerd-out.com./forum/read.php?f=17&i=3139&t=3139
This stops the apex 660 from automatically turning on subtitles (it also has macrovision disabled
how do you fix a mencoder bug when using devede?
By keithkreo in forum LinuxReplies: 1Last Post: 31st Dec 2009, 16:20 -
fix short subtitle
By Cowabunga in forum SubtitleReplies: 2Last Post: 23rd Feb 2009, 14:14 -
Pioneer DVR-555H-S DviX subtitle bug!!!
By Ledd in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Apr 2008, 11:05 -
fix subtitle
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 21:19 -
avsFilmCutter bug fix
By ebobtron in forum EditingReplies: 0Last Post: 13th Jun 2007, 14:03
