Hi. I’d like to know if there’s a way to stretch several split audio events as if they were one. Selecting all of them and then apply stretch won’t work.
I also tried to group them by G, CTRL-G or Menu-Group Events and then strecth but only the event where the cursor is in seems to be affected.
I would like to do that without having to render to a new track and then stretch.
Thanks.
A lot of times, you'll need to make a new track...but re-encoding audio isn't as noticable as video...(as if video was noticable)
I've found audacity can handle most of my needs... -
*select all the wanted clips
*create new group
*reselect clips
*hold down Ctrl key and stretch away....
Need help mapping season episode to grouped chapters on a DVD
By nzdreamer55 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 17:12 -
How to stretch video clip in Vegas
By MI6 in forum EditingReplies: 1Last Post: 3rd Aug 2010, 12:51 -
Sony Vegas 9: Copy events/sounds from one file to another?
By duderdude2 in forum EditingReplies: 3Last Post: 15th Feb 2010, 22:42 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Can't stretch this video from Sony DVD camcorder (standard definition)
By edong in forum Authoring (DVD)Replies: 2Last Post: 16th Oct 2007, 12:47
