I have 33 clips that I wanna join.It's actually a movie that's been cut into 33 parts.So now I wanna join these AVI files but when appending the 19th part.the audio begins to go out of synch.Is there a better avi joiner that joins video without losing its quality at all?
I can't live without my computer.
If you set both modes to copy, AVI Demux will only "smart render" - that is, it will only render what must be rendered.
All simple joiners (which is all you are using Virtualdub as in this case) only work if all the parts of the video are identical. If they are not, some parts will have to be adjusted (read : encoded) and problems like audio sync may arise.Read my blog here.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30
