This is a great program but I have one problem.
I created an album containing pictures, video clips and music. Total time about 57 mins and size about 2.6Gb
I then generated the video disk image and burnt it to disk in one operation. Resulting DVD appeared perfect and played on computer and DVD player BUT only 45 mins of the album has been burnt to the disk.
I thought it may be my burner so I then regenerated the video disk image and had it saved to the hard disk. Exactly the same result - only 45 mins were burnt to the image file. The Video TS directory is only 1.8Gb in size
Each time I had cleared the cache before starting.
I'm using Vista Ultimate and have 25Gb spare on the hard disk
Has anybody got suggestions re what I am doing wrong or how I fix the problem
Many Thanks
I discovered the reason and solution last night so I thought I would post it here in case someone else had the same problem.
Basically it was all caused by a corrupt jpg file in the album. During preview the album played to the end with just a black screen when it came to the corrupt file. However it seems as though when creating the image file as soon as the program comes to the corrupt jpg it saves the image file up to that point.
I removed the corrupt jpg and all was well -
I'm about to embark on a similiar project, so I'll "file" away your fix, just in case.
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
DVD memories - the early days!
By lordsmurf in forum MediaReplies: 5Last Post: 14th Jan 2009, 22:06 -
Memories to TV mpeg quits at 27 %
By pcbrown in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 06:54 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
