Hi, I'm using ffmpeg to encode some videos to flash for my website, but I've noticed that after the videos have been encoded they do not have any kind of seek bar or progress bar that tells you the time of the video. Everything else works great, but I cannot get a seek bar. I know it's not my player either because I have tried it with other flash videos and those ones have the seek bar. Any ideas?
Possibly the FLV files do not have meta data, such as duration, attached to it. ffmpegX uses flvtool2 (an optional separate install) to add meta data to FLV clips. Did you install flvtool2? Did you verify it working properly by checking the Process Information log
How to get rid of this nav bar
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2012, 21:40 -
Full Time Seek Bar
By Bruno AUgusto in forum Software PlayingReplies: 2Last Post: 17th Nov 2011, 07:52 -
Help with audio in bar please
By theflame01 in forum AudioReplies: 0Last Post: 30th Apr 2010, 06:21 -
Wii Sensor Bar
By Squid_uk in forum Off topicReplies: 5Last Post: 26th Jun 2009, 21:03 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29
