Hi All,
Im trying to create a menu where there is a motion menu and have added 3 cells
Cell 1 = Intro
Cell 2 = Movie with loop and buttons
Cell 3 = Outro.
Now I got the intro, movie loop and buttons to work but when you press the button it links to cell 3 plays it and the freezes and doesn't go to the movie. I was wondering if this is because I had to trim a bit of the menu movie or whether I'm just doing something wrong in the setup of the cells
You can endlink menu to the movie, than when you push play it will go to Outro and to movie.
Other buttons will link directly to other sections.
If you want all buttons to go through Outro to different parts, you will have to use Register value for each button and VM Command to direct it there form Outro.
DVD Lab Pro 1.6: Links in menus get blue under fresh Windows installation
By Paker in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2011, 12:54 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 15:02 -
[DVD-lab Pro]Links dissapear/ cell linking
By Ninerian in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2008, 07:11 -
One Cell Motion Render in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2008, 09:07 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 18:10
