Sorry to bother you but i seem to be a bit stuck adding subs to a movie.I think i have done it right by finding what sub stream i need in media info then extracting the subs to the same folder as the source with mkv extractor.Then i have started TMPGEnc 4.00 chose the file to encode .I then have entered the clip editor window and enabled the sub filter,Now this is were i seem to be going wrong,Once the filter is in the filter list i tick it to enable it then go into edit menu and try to import the subs from the directory were the movie is.This is were i`m stuck nothing shows up at all in the box were you are supposed to see the text.Am i doing something wrong ?.I have made sure that the mkv file in question and the srt file are the same.I have also opened the same file up in win avi and i picks up on the srt.I just can`t seem to get this right any help on this matter would be great.
Thanks in advance.
Results 1 to 1 of 1
1920x1080 / 59.94i Footage From High-Def Camcorder - TMPGENC Auth. Works 4
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 19th Oct 2010, 12:31 -
hard encoding .srt subs to avis
By ninmario4life in forum SubtitleReplies: 3Last Post: 8th Nov 2009, 15:35 -
re encoding MKV files with subs to smaller file sizes with min qual. loss
By malakov08 in forum MacReplies: 1Last Post: 4th Apr 2009, 02:06 -
subs loses quality after encoding
By evile1690 in forum SubtitleReplies: 11Last Post: 2nd Sep 2008, 08:17 -
How may I record in High Def and Playback in High Def ?
By MacPCConsultants in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jun 2008, 16:28
