Hi everyone,
I have a question about the effect used in Adobe products, known as time warp.
Does anyone know how successful this effect is at creating slow motion video from frames shot normally?
I'm thinking of swapping from Vegas to Adobe Premiere for this reason, but I'd like to know if this effect can actually create realistic slow motion effects, using pixel motion to generate in-between frames, or if it's just a 'next best thing' to actual slow motion.
The only examples I've seen are low res, where it's hard to tell just how well this software works. I'd only be interested if it can acheive believeable results on a large screen in standard definition DVD format.
Also, does anyone know of any stand-alone software that can do the same or similar things, that would save me learning a new platform?
Thanks a lot guys.
Results 1 to 1 of 1
Adobe License Agreement every time
By gooberguy in forum ComputerReplies: 8Last Post: 6th Jun 2012, 15:33 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 21:43 -
how to capture a still in adobe primer time line where video placed
By muddassarsaadi in forum EditingReplies: 2Last Post: 26th Jul 2010, 14:34 -
Adobe Premiere Elements 2.0 and 4.0 installed at the same time
By Mållgan in forum Capturing and VCRReplies: 0Last Post: 26th Aug 2009, 01:21 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
