Which program is best to join cut avi files?
What format AVI files? There are dozens of AVI type formats.
But AviDemux and VirtualDub (Mod) should work for most.
Both Xvid, where do you go to join it in virtualdubmod?
Nvm i found out but the frames rates are different... any solution for this?
Generally, the framerate, frame sizes, audio formats have to match to be able to join two files. AVIDemux may be a little more flexible, but not much.
Most times you just have to change one or the other to match (Re-encode) to join them.
If your final format is MPEG for a DVD, you could just encode each separately to DVD compliant format, then let the DVD authoring do the joining. -
aiite I found out a way, since the 2nd file was small it doesn't take much time. Thanks for the help.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 14:17 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22
