Hi,
I am searching for a plugin or something that will give an old analog scramble channel effect. Is there a way to modified the scaning process vertically and horizontally.
Thanks in advance for your help.
Plugin for what ? There are after effects plugins that can do this : eg. http://www.digitaltrove.com/prime/effects/tv.html
Read my blog here.
i was thinking a avisynth plug-in or I have also Ulead.
I'm asking so any suggestion of a program or a way to acheive this effect is appreciate.
I'll check the after effects. thanks! -
You might be able to get what you want from a combination of effects from this virtualdub plugin (also callable form avisynth) from MSU : http://www.compression.ru/video/noise_generation/index_en.html
Read my blog here.
In my experience, analog TV scrambling results in a very wavy picture with chroma shifts, not static noise. Something like this (done with warp and chroma shift filters in a paint program):
but more extreme and more random.
Searching for a synchronizing and video/audio editing software
By Raziel in forum EditingReplies: 4Last Post: 2nd Jul 2011, 12:36 -
Philips BDP7320/F7 with Netflix and 7.1 Channel Analog Output
By Big C in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Aug 2010, 17:51 -
Disapperaing analog cable channel on a split signal?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2008, 10:42 -
Recommendations for DVD player with 6 Channel Analog Output
By dp_dvd in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Sep 2007, 19:56 -
Changing Channel Effect
By MOVIEGEEK in forum EditingReplies: 1Last Post: 27th Jul 2007, 12:19
