Hi!
I've been doing quite a bit of research about how to convert high profile mkv files into something appletv can play. I've got perian running on it, but apple tv doesn't have enough power to handle mkv's. But that is neither here nor there.
My problem is attempting to convert the mkv to something that appletv can handle. I also need to do this on the command line without user intervention. Finally, I'd like to demux it rather than re-encode the whole thing.
What I've found so far is...
1) mkvextract tracks <filename> 1:video.h264 2:audio.ac3
2) use hexedit to change some strings in the file
3) mp4box -add video.h264 -add audio.ac3 output.mp4
This kind of works... First, you have to use something like hexedit or lvlchange.exe to change some strings around. On linux, I'd rather not use wine to run lvlchange and I just feel like there has to be an easier way. Second, on my MBP, when I play the file in Quicktime, the processor spikes and the video is choppy. Now, I'm guessing that if this happens on my MBP, it will choke appletv.
So now, I'm back to square one. I am hoping that somebody out there can suggest something because I know that there has to be a way to do this. Thank you in advanced for any help...
Results 1 to 1 of 1
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Linux command line tools for Converting AVI to H264/AAC mkv
By Psykro in forum LinuxReplies: 9Last Post: 6th Oct 2011, 21:21 -
software to manually set an AR in an mkv files (LINUX)
By graysky in forum LinuxReplies: 2Last Post: 10th Apr 2009, 16:45 -
AppleTV - Conversion of MKV to HD MP4
By Austehn in forum Video ConversionReplies: 7Last Post: 22nd Oct 2008, 19:28 -
.MKV to .MP4 (or .MOV) for AppleTV
By RevMayhem in forum Video ConversionReplies: 3Last Post: 3rd Feb 2008, 17:37
