Hi all, hope someone can help...it's driving me crazy. I'm using Vista, and I have an Avermedia AVerTV Combo PCI-E M780 tuner card, and when I record something in HD into mpeg2 format using their aver Mediacenter software, I don't hear any audio when I play it back in either WMP11 or VLC media player. If I check out the file in gspot, it says the audio is AC3. If I look at the properties of the file in WMPI1, it says there's no audio track....there's just a dash next to "audio codec:". I installed the AC3 filter, v1.51, and it didn't fix the problem. I think I'm using the wrong demultiplexer or something. How do I tell windows to use a different setup?
When you playback the video do you have "spdif out" enabled? HOw do you normally hear digital sound out of your computer? I would make sure that digital out is enabled to be sure the correct sound is outputted. You would look for this option in your playback software.
issues to play ac3 audio with WMP12 in windows7 64bit
By deejay.2001 in forum ComputerReplies: 0Last Post: 24th Jul 2011, 20:45 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
cant play mkv with ac3 audio on samsung LE40C530F1W
By swarnpalsingh89 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2010, 14:19 -
play mkv file with external ac3 audio???
By zzyzx2 in forum Software PlayingReplies: 9Last Post: 12th Apr 2009, 23:20 -
can't play mpeg2 w/ ac3 audio
By jlatenight in forum Software PlayingReplies: 4Last Post: 14th Feb 2009, 16:58
