Hy support,
I recently purchased sony vegas movie studio 9, just to discover that there are only 2 preset resolutions available. They are 720 x 480 and HD.
This is very limited and I wish I had known earlier,
before I purchased it. Virtual dub is free and will
allow any resolution. I am currently editing videos
that are only 320 x 240, but when I edit them with
sony movie studio, it will then only give me the
option of either 720 x 480 and HD. The idea was for resolution to remain the same after edit and save avi file at 320 x 240.
please can you explain ?
I'm still using Vegas Studio 7 Platinum, but I would imagine v. 9 has at least the same functionality, if not more.
Others might be able to help you more, but this should get you started.
Click:
- file
- render as
The "Render As" window opens
- Change "save as type:" to "Video for Windows (.avi)"
Click the "custom" button to the right of "template: NTSC DV"
At the bottom of the "Custom Template" window click the "video" tab
In the "video format" pull down, select a different video codec, such as "Microsoft Video 1"
Now the "frame size" pull down higher up in that screen is enabled (no longer grayed out)
Pull the "frame size" down and select "Multimedia (320 x 240)"
Pull the "Quality" slider all the way to the right ("high")
If you want you can save this template with a name so you can recall the settings (top of window)
Click "OK"
Now you're back at the "render as" window, but using your "custom" template
Render and playback with your media player of choice to check your results
Modify the template and try different settings if the ones you chose didn't work the way you want.
Good luck!
Sony Vegas - Scripting - Adding track motion preset
By samsam in forum EditingReplies: 1Last Post: 7th Oct 2020, 01:52 -
Trying to edit various source clips, different resolutions in Sony vegas
By sevenofone in forum EditingReplies: 4Last Post: 30th Jan 2011, 17:29 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
Sony Vegas 8 - Track Motion Preset saving???
By sdsumike619 in forum EditingReplies: 2Last Post: 4th May 2008, 01:47
