Has anybody ever successfully replaced the DVD drive in a Panasonic recorder? I've searched this site and not found an answer. Just wondering if it is as complex (service disk, service remote, etc) as the Pioneer procedure for DVD / HDD replacement / upgrade. Will I be a pioneer (pun intended) in this procedure?
Thanks in advance.
Other than replacing your own drive most people opt for the $130 flat fee that Panasonic provides. By the time you consider the cost of the drive and trouble $130 seems well worth it to most.
http://www.avsforum.com/avs-vb/showthread.php?p=14451738#post14451738
I don't know a lot about drive replacements but from what I've read Panasonics don't require a service remote like Pios and if you install a drive larger than the factory drive it will only recognize the amount of the original drive. IOW installing a larger drive than original will not give you more recording space. -
I guess I should clarify ... I am asking about the DVD burner not a HDD. The DMR E50/E55 do not have hard drives.
Oops, sorry I missed that. In that case what I've read that others have done is to cannibalize a similar year recorder and use that drive.
In your case a ES-15 would have the same DVD drive and it would just be a matter of swapping the drive. The ES-15 would be the cheapest recorder with a similar drive to your EH-55. Drives from different year Panasonics will not work. You need a '06 model year DVDR. Note even though the EH-55 was sold new in Canada through the early part of '08 it's still a '06 model year design.
Replacement for Panasonic DMR-E500H
By brycer in forum DVD & Blu-ray RecordersReplies: 16Last Post: 2nd Feb 2012, 00:12 -
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 17:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 10:42 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34
