Hey,
I've a 704MB DivX file I want to re-encode into Xvid.
I opened VirtualDub, opened that file, set video compression on Xvid and 1st pass. Added to Job
then second pass, added to job.
I started the job control jobs and got an output file that is so small it's funny :
I got : movie.first.avi - 76MB
video.pass - 2.09MB
movie.second.avi - 83.5MB
What did I do wrong ???
Thanks guys,
Anna.
Why reconvert to xvid? Most stuff that supports xvid also supports divx.
But if you want to reconvert I would instead use avi recomp. -
Maybe the audio settings are wrong?
In the "audio" menu: is "Direct stream copy" active?
I am telling this because if you recode audio to another format the file size might increase.
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 05:19 -
Two-pass XviD encoding in VirtualDub
By wallywalters in forum Newbie / General discussionsReplies: 4Last Post: 18th Jun 2012, 00:11 -
VirtualDub + Xvid: problem with file size in 2 pass encoding.
By marcinkk in forum Video ConversionReplies: 3Last Post: 8th Dec 2011, 15:47 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 21:11 -
Solved- How to do 2 -pass avi encoding with VirtualDub Mod
By jimdagys in forum Video ConversionReplies: 0Last Post: 22nd Nov 2009, 23:07
