Is it possible to enhance the video quality of "home-burned" DVDs? I have some video concerts that have been burned to DVD - I'm not sure of the source, probably VHS - of which the video quality ranges from low resolution (unclear, fuzzy images) to really poor (RF –type interferences). I currently have DvdReMakePro3 and ImgBurn. Do either of these two programs, or other software programs allow for such a thing?![]()
You may find that the horse has already bolted. If you can get the original VHS tapes and capture them with less damage, then work on the video, then encode (carefully) for DVD, the results may be more pleasing. However restoration is a complex hobby and not a one-click process. It may take a combination of different filters and settings, a lot of trial and adjustment, and is made more difficult if you source is heavily compressed (e.g. DVD), as you may end up having to clean up the encoding as well as the original problems.
You also have to weigh up just how much benefit is to be gained from the exercise, as every time you re-encode the video, you risk losing quality.Read my blog here.
Video Enhancer-VirtualDub like program-to enhance video-when upsizing!
By Milardo in forum EditingReplies: 43Last Post: 9th Apr 2015, 21:39 -
Video enhance
By Videographer in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2011, 16:10 -
DVD to HD (resize and enhance image quality)
By SB4 in forum RestorationReplies: 12Last Post: 14th Dec 2010, 16:54 -
Enhance Video Software
By Teac23 in forum RestorationReplies: 17Last Post: 3rd Mar 2009, 10:09 -
How can I enhance / sharpen this video?
By ferrous in forum RestorationReplies: 2Last Post: 22nd May 2007, 16:10
